Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 820 pistons
[Show Entire Topic]  [Return to Forum]
buickanddeere
01-31-2013 08:52:49
184.151.61.102
Which two cylinder 820? Pumps, injector tips and pistons vary.
[Reply]   [No Email]
skip33652
01-31-2013 21:00:16
68.69.83.56
Re: 820 pistons in reply to buickanddeere, 01-31-2013 08:52:49
Originally there were two different bowl designs for the 80-830 all sub to late design and will work with either green dash or black dash tractors.
  [Reply]  [No Email]
Greenman720
01-31-2013 09:22:36
71.59.188.158
Black dash
  [Reply]  [No Email]
Greenman720
01-31-2013 09:21:12
71.59.188.158
Sorry the diesel engine
  [Reply]  [No Email]
buickanddeere
01-31-2013 11:35:48
209.240.120.229
Re: 820 pistons in reply to Greenman720, 01-31-2013 09:21:12
Something to consider would be strapping the main bearings, crank, rods, cylinder block, cam, followers,head , pumps on thier mount and the injectors. And send it all to Albert. Everything will come back correct and ready to bolt on. Tractor will run better than it did factory fresh.
Price will be right and you will have peace of mind that everything is exact .
  [Reply]  [No Email]
Kent Petersen
01-31-2013 12:46:53
209.62.225.173
Re: 820 pistons in reply to buickanddeere, 01-31-2013 11:35:48
is that the way you do it B&D. if so you must be very rich
  [Reply]  [No Email]
buickanddeere
01-31-2013 13:54:08
184.151.61.102
Re: 820 pistons in reply to Kent Petersen, 01-31-2013 12:46:53
Doing the job right the first time is usually cheaper than doing the job over a 2nd time.
Shipping is cheap.
One trip to send and receive the parts saves a lot of valuable time and fuel to run around for parts and shops.
RT is a shop that has specialized in diesel two cylinders for decades. Asking billy bob down a Bubba's machine shop, bait, tackle and marital advice services if he has ever machined a two cylinder before . Sometimes they don't admit they don't have the proper tools for a 6+ inch bore. Main bearing clearances and bearing materials have caused some serious problems.
  [Reply]  [No Email]
jake winn
01-31-2013 21:00:08
75.170.31.228
Re: 820 pistons in reply to buickanddeere, 01-31-2013 13:54:08
I know B-D"s comments sound it a bit rough at times, but hes just trying to make a point, and a good one he does. If you are going to the trouble to put pistons in it, chances are there are other things that it needs. If you are going to do that deep of work, youre right there to put in new bearings and have the fuel system done. Is it expensive, sure, but as he says, its cheaper than going back and doing it a second time. Are these machines complicated? in the grand scheme of things, no not really, but they have little things that can bite you if you dont know the tricks. Albert Ulrich (Rennisance Tractor) can make a two cylinder diesel run like no other ive ever seen. And im talking about a tractor you can take out and work all day, not one to go 300ft at a time and youre lucky if it lasts to get on the trailer.
  [Reply]  [No Email]
FactoryFarmer
01-31-2013 18:34:17
184.21.136.51
you make it sound like nobody can work on these engines, before I started restoring tractors nobody around here had even seen a head off a diesel 2 cylinder, I've never had a problem.
  [Reply]  [No Email]
B-maniac
01-31-2013 13:26:20
97.92.51.58
....heck, for another $8000 , Chip Foose can have the exterior looking better than factory fresh also. Send it , it's just money.
  [Reply]  [No Email]
mbdeere
01-31-2013 12:33:02
184.63.147.142
Who is Albert?
  [Reply]  [No Email]
buickanddeere
02-01-2013 05:08:03
184.151.61.102
Re: 820 pistons in reply to mbdeere, 01-31-2013 12:33:02
To be honest I was positive I had included Renaissance Tractor in with Albert. Even spell checked Renaissance tractor but must have lost it in the cut and paste. Could not expect you to know Albert on first name alone. Sorry.
  [Reply]  [No Email]
Bob Harvey
01-31-2013 19:21:00
209.121.225.183
I don't mind giving away any of my gaziilion dollars to scammers and "ne'er do wells", but we definately need to know who 'Albert' is.
  [Reply]  [No Email]
buickanddeere
01-31-2013 19:35:13
209.240.120.229
Re: 820 pistons in reply to Bob Harvey, 01-31-2013 19:21:00
If you and MB sitting at your computers can't find Renaissance Tractor on your own. There is no use trying to tell you.
  [Reply]  [No Email]
Wilamayb
01-31-2013 21:00:49
71.15.146.140
Re: 820 pistons in reply to buickanddeere, 01-31-2013 19:35:13
Not a personal attack, but how would they have even know to look for "Renaissance Tractor" until you made this post? How would they have know that "Albert" owned a business called "Renaissance Tractor" unless you told them?
Did I miss something?
  [Reply]  [No Email]
buck eye al
01-31-2013 15:45:54
168.251.194.18
I can claim I'm albert.... BUT not the one they're talkin of!
Later.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
