4240-draft control lever stuck
Anonymous-0
I disconnnected the linkage to the control lever on the rockshaft housing and fine it stuck. Has anyone experience with this and a fix? Thanks for your help
"Don"t" get hammer happy with it that aluminum lever, it breaks rather easy, spray it and "tap" it a bit,in and out up and down gently, the rust holding it is a small amount just inside the edge, where the moisture work in.Take care and try not to break it, they are ornery to replace..
