Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
Re: Clutch ?s
Tx Jim
01-31-2013 03:58:18
How deep do dogs go into toggles?? How worn is the hole in the clutch hub that slides on a pin in the clutch pulley? If the hole is oblong it will let the hub move altering the dimensions on the toggles & dogs.
01-31-2013 04:36:27
 Re: Clutch ?s in reply to Tx Jim, 01-31-2013 03:58:18
well ill have to measure on the dogs later then. they go in where all the round part is in the dog. on the other the slide hole is good and round and tight i checked that also. i havent really checked the hole that the toggle sits in on the slider either.
02-01-2013 07:17:28
 Re: Clutch ?s in reply to mlbtex, 01-31-2013 04:36:27
Here is what I do , clean the toggles in solvent. Then put a dog and toggle together , tilt the toggle to the side . If the toggle hits the side of the dog , the dog is worn out,and will bind up. Usually you will see a worn ring (shiney) where the toggle hits
