TractorLinks.com
Show Parts for Model:
Re: John Deere 2010 Hydrualics Problem
buickanddeere
01-30-2013 20:18:48
In all honesty and no offence intended. Sorry but the 2010 is a pityful peice of crap. That can not be fixed due to numerous design flaws and a shortage of parts. On behalf of the other posters and readers here. We wish you had checked here before purchasing the 2010 and that we could have stopped the sale. It's about 50 years past the best before date. time to scrap it and move on.
CJF1981
01-30-2013 20:29:00
 Re: John Deere 2010 Hydrualics Problem in reply to buickanddeere, 01-30-2013 20:18:48
Buickanddeere,
No offense taken. Other than the hydraulics issue, the tractor starts up well, and I've used it to skid logs/pull things. I skidded over 7,000 board feet of hemlock this past year to side my 65 x 40 barn. Some of the logs were 18 feet and over 2 ft in diameter. i bought it several years ago before finding these forums. It is definitely not a popular model as far as John Deere goes. To be honest, I paid 3,000 for the tractor. I spoke to a guy recently that could test the pump and he mentioned he could put a new hydraulic pump in it instead of paying for a rebuilt pump. I assume by what I've tore into and looked thru in the manuals, its not an easy switch to convert to a newer pump. Any thoughts?
Todd Young
01-30-2013 21:59:35
 Re: John Deere 2010 Hydrualics Problem in reply to CJF1981, 01-30-2013 20:29:00
I own a JD 2010, and everyone is right, it is a piece of junk. Most complicated system on earth, and everything is INSIDE the tractor. I have a JD 2020 also, it"s a very nice easy to work on tractor. I gave up on the 2010. It"s now collecting dust, because I can"t sell it. I can be fixed but it will be hours of labor. More than likely the problem isn"t the pump. Did you make sure the pump is running? You can turn it off down by the foot petal? On mine I got remote working, but the 3 pt. won"t lift anything. Inside the lift it looks like an erector set. I am thinking of just gutting the rear and hooking the hydraulic cylinder up directly to the remote system some how.
Take Care,
Todd
CJF1981
01-31-2013 05:52:38
 Re: John Deere 2010 Hydrualics Problem in reply to Todd Young, 01-30-2013 21:59:35
Todd,
Thanks for the reply. I am hoping it is not the pump, but it seems to be pointing that direction. When you say you can turn it off down by the foot petal (you mean on the clutch side?). The manual calls for disconnecting the throwout arm and spring. When I disconnected the throwout arm, I never found a spring even though there is a hole on the outside (below the clutch) for one. I was able to pull the throwout arm as the manual called for. I started working from the access door on the right side of the tractor (below the foot petals) and its a very tight space to work in. I have heard people say the guts are put together like a swiss watch and the parts shown in the instruction manuals verify that.
Chris
Todd Young
01-31-2013 11:43:31
 Re: John Deere 2010 Hydrualics Problem in reply to CJF1981, 01-31-2013 05:52:38
Does your remote work on the rear of the tractor? If nothing is hooked up to the remote and you pull the lever on the dash for the remote does the motor strain any? If it does the problem is not the pump. The problem is more than likely a relief valve in the system is stuck open or has a broken spring. Had not had time to tear my own tractor apart yet, but I'm sure it's going to be fun. Take Care, Todd
KEH
01-31-2013 06:52:27
I had a 2010, not bought new. I found that it was necesary to put in a new hydraulic filter from time to time. Probably the old one could have been cleaned by boiling it in some cleaner, like maybe an ammonia mix, but ordinary cleaning in gasoline was not enough.
KEH
CJF1981
01-31-2013 10:22:35
 Re: John Deere 2010 Hydrualics Problem in reply to KEH, 01-31-2013 06:52:27
KEH,
Thanks for the reply. I cleaned the filter out and it looked brand new when I was done. I also got new seals as well.
Chris
