TractorLinks.com
Show Parts for Model:
Re: 4430 wont move in any gear
Bowes 01
01-30-2013 17:31:44
I think its what they call perma clutch system.And let me refrase it will try to move in all gears and finally it will start moveing real slow and then when it starts to get a little warm it quits completly.
Thanks
Tim S
01-30-2013 18:08:26
 Re: 4430 wont move in any gear in reply to Bowes 01, 01-30-2013 17:31:44
Possibly the clutch is "clear" out of it,,or the differential spider gears are wiped out, if this happens it usually knocks the transmission pump off the back of the case, also killing the hydraulics..engage the diff lock and see what happens...
Bowes 01
01-31-2013 11:14:23
 Re: 4430 wont move in any gear in reply to Tim S, 01-30-2013 18:08:26
hyd work fine,filter and oil been changed.Dont understand why it wonts to move when cold then as it warms up nothing.Thanks
Tx Jim
01-31-2013 12:06:43
 Re: 4430 wont move in any gear in reply to Bowes 01, 01-31-2013 11:14:23
Oil is a little bit thicker when it's cold compared to operating temp.
Tim S
01-31-2013 11:44:34
Have you tried to move it with the diff lock engaged?? This will prove the differential is good, ,if it still will not move with the diff lock engaged then the clutch must be bad.
Bowes 01
01-31-2013 15:06:51
 Re: 4430 wont move in any gear in reply to Tim S, 01-31-2013 11:44:34
Yes it will still not move with diff locked when cold.I am thinking two speed clutch is the problem,cause the perma clutch on the flywheel alows you to put it in gear and also controls pto whick both are working.Tell me what yall think.
Thanks
Tim S
01-31-2013 15:25:18
 Re: 4430 wont move in any gear in reply to Bowes 01, 01-31-2013 15:06:51
It is most likely the transmission clutch..
Tx Jim
01-31-2013 16:32:49
 Re: 4430 wont move in any gear in reply to Tim S, 01-31-2013 15:25:18
Bowes 01
I agree with Tim on traction clutch.
Bowes1
02-02-2013 20:22:01
 Re: 4430 wont move in any gear in reply to Tx Jim, 01-31-2013 16:32:49
Thanks To All For Replys,turns out planitary cluth disc worn out completly.
Thanks Again....
