Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 440 Crawler
[Return to Forum]
Wratchet tx
01-29-2013 20:19:55
66.209.250.159
I am looking at a JD 440 Crawler (GM 2cyl) but one of the tracks will not stay on the rollers. It is not where I can get it on hard dry ground to look. What is most likely the problem with the track/rollers/???
[Reply]   [No Email]
pcsaw
01-30-2013 12:09:26
204.210.228.87
Re: 440 Crawler in reply to Wratchet tx, 01-29-2013 20:19:55
take a spud bar and see if the sprocket has play in it.
  [Reply]  [No Email]
buickanddeere
01-30-2013 07:42:56
184.151.63.251
A sweet but expensive mistress to maintain.
What about sprockets, front idler track wheel and the small upper and lower rollers?
There maybe enough clearance gained with new fronts, new sprockets and 12 new idlers to run the worn tracks for quit some time.
Steering clutches need to be inspected too.
Use a coolant heater instead of ether on the 2-53 Detroit. The originonal S series 53's did not start worth beans at below 50F.
There are piston, injector, blower and valve train spring updates from Detroit for N series specs. Wouldn't know it was the same engine with the improvements.
  [Reply]  [No Email]
730d se
01-30-2013 05:21:03
68.189.186.53
Either the chains and rollers are worn past 100% and/or not adjusted properly. If they are too loose, the will slip off.
It is a 440 ICD (Industrial Crawler Diesel).
  [Reply]  [No Email]
JohnDeereJimOhio
01-30-2013 05:18:59
204.9.147.16
They are either completely wore out or need adjusted. On the bottom rail there should be two 1-1/4 nuts on the outside and inside. You have to tighten them the same. So ten turns on inside you need ten turns on outside. On my 420c the book says lay a 2x4 across the top of the track and when its at the right tightness from the center of the 2x4 down to the track should be 1-1/2 or 2 inches in the middle something like that I would have to look it up. It could also just be that the tracks are completely shot? Mine are not great however I have room to tighten and mine is a play toy. Finding new tracks or 50% used one is a big expense. You can also try jdcrawlers.com Levoy own the site and sells parts. There is also a forum with guys that know a lot about crawlers. I have the book and can look up your info when I am in the shop on Friday if you need me too. Hope this helps...
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
