JD 80 power steering pressure line gland nut needed
I have a power steering unit from an 80 tractor that has the bottom O ring leaking -easy fix -the pressure line is one complete unit with the fittings on the pipe -the end of the line that connects to the power steering box, the gland nut has the threads damaged - The internal threads on the housing look OK - has anyone found a replacement gland nut? or I guess I need a complete line with good fittings?
Ken
