| John Deere Tractors Discussion Forum |
Topic: Re: '66 Powershift PTO won't stop at 1900 RPM
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| dweitzel
01-28-2013 19:08:49
72.49.81.47
I'm calling the "BR" port the one to the right and the "CL" is to the left or front of the tractor. I do not have my manual in front of me. I hope I'm describing them correctly. |
[Reply] [No Email] | |
| dweitzel
01-29-2013 14:28:49
74.215.54.8
Re: '66 Powershift PTO won't stop at 1900 RPM in reply to dweitzel, 01-28-2013 19:08:49
| | Ok, did some more testing today. Decided to pull the oil pressure regulator from the bottom of the transmission, below the PTO valve. Found 8 shims in the assembly. Removed all the shims, tested the PSI at about 120 and PTO would not shut off at any RPM. Replaced the 8 shims and inserted about 4 more shims (washers) and that brought the PSI to 180-185 and the PTO now works correctly. Now the question is why do I need the PSI on the clutch port to be 30 PSI above the specs called for? Is this going to hurt anything to leave it this high? I guess I could remove a few washers and maybe set it down to 170-175 and see if that works. I could live with some no load rotation and set the PSI down a bit. One other question, would setting the PSI up this high cause any leaks from the front of the transmission input shaft? I have drips about every 8 seconds coming out the weep hole in the bottom of the bell housing now? :( Anyone with a powershift care to chime in. How much spin is normal after turning off the PTO at high RPM"s? At 185 PSI, the pto shaft without anything hooked up stops immediately after shutting off the PTO lever? Am I expecting too much from a 46 year old tractor? Thanks. |
| dweitzel
01-29-2013 17:02:27
74.215.54.8
Re: '66 Powershift PTO won't stop at 1900 RPM in reply to dweitzel, 01-29-2013 14:28:49
| Guess I missed something. Looked at the manual and it appears I've been testing the "Clutch" port and the "PTO" port. I did not know the "BR" test port is up higher and behind the inching pedal. Guess I need to get that snap ring off and get my gauge on the "BR" port to see what the pressure there is reading. I'll put the correct shims back in the pressure regulator and pull the inching pedal and test the "BR" port. Missed that one. Stay tuned. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
