TractorLinks.com
Show Parts for Model:
Re: '66 Powershift PTO won't stop at 1900 RPM
dweitzel
01-28-2013 19:06:34
Maybe I did not explain correctly. The test port "BR" is zero psi when the pto lever is off, and 155-160 at 1900 RPM when the pto is on.
The "CL" port is a constant 155-160 psi at 1900 rpm. The "CL" port fluctuates only slightly when I press in the inching pedal.
If the pin is sheared, why does the pto work correctly when the rpm is less than 1200? at 1200 RPM and below, the pto functions normally?
dweitzel
01-28-2013 19:08:49
 Re: '66 Powershift PTO won't stop at 1900 RPM in reply to dweitzel, 01-28-2013 19:06:34
I'm calling the "BR" port the one to the right and the "CL" is to the left or front of the tractor. I do not have my manual in front of me. I hope I'm describing them correctly.
dweitzel
01-29-2013 14:28:49
 Re: '66 Powershift PTO won't stop at 1900 RPM in reply to dweitzel, 01-28-2013 19:08:49
Ok, did some more testing today. Decided to pull the oil pressure regulator from the bottom of the transmission, below the PTO valve. Found 8 shims in the assembly. Removed all the shims, tested the PSI at about 120 and PTO would not shut off at any RPM.
Replaced the 8 shims and inserted about 4 more shims (washers) and that brought the PSI to 180-185 and the PTO now works correctly.
Now the question is why do I need the PSI on the clutch port to be 30 PSI above the specs called for? Is this going to hurt anything to leave it this high? I guess I could remove a few washers and maybe set it down to 170-175 and see if that works. I could live with some no load rotation and set the PSI down a bit.
One other question, would setting the PSI up this high cause any leaks from the front of the transmission input shaft? I have drips about every 8 seconds coming out the weep hole in the bottom of the bell housing now? :(
Anyone with a powershift care to chime in. How much spin is normal after turning off the PTO at high RPM"s? At 185 PSI, the pto shaft without anything hooked up stops immediately after shutting off the PTO lever? Am I expecting too much from a 46 year old tractor?
Thanks.
dweitzel
01-29-2013 17:02:27
 Re: '66 Powershift PTO won't stop at 1900 RPM in reply to dweitzel, 01-29-2013 14:28:49
Guess I missed something. Looked at the manual and it appears I've been testing the "Clutch" port and the "PTO" port. I did not know the "BR" test port is up higher and behind the inching pedal. Guess I need to get that snap ring off and get my gauge on the "BR" port to see what the pressure there is reading. I'll put the correct shims back in the pressure regulator and pull the inching pedal and test the "BR" port. Missed that one. Stay tuned.
