oil pump shaft coupling
I have a 1939 model A and the oil pump shaft coupling broke. The Dealer's book didn't show it.Does anyone know where I can get one. Thanks
part# B250R, if you have both halves, i've welded them back together again. The new one will be heavy duty and not look like the original.
Is it better to use the thin walled one or the new thicker one? If tractor is to be use on the warm temps.
They are designed to break so they dont strip the cam gears.
You know why it broke don't you? Ice around the oil pump gears. Then when you try to start engine something has got to give, ice or coupling.
I have them available . I want $10 each plus shipping. I have one hanging on the wall that some one welded. It came out of an A with a siezed up left main bearing when it split the second time. Do what you want. Contact me at 573 535 8952 or email . Thanks , Tom
Thanks for the offer I think I'm going to weld it and see how that works out. The tractor set for a long time and there was water in the bottom that was froze.
