TractorLinks.com
Show Parts for Model:
Re: 4020 Powershift
Cliff Nelson
01-28-2013 09:34:11
Access to the pawl requires removing platform and trans cover. To replace the pawl you need to remove the rockshaft, pto shaft, and load control arm in order to remove the park pawl shaft. I just finished one that the return spring was broken and the retaining rings on the pawl shaft were gone. New shaft is different than original and is installed from rear. I believe the book says to double split and remove from front but that will not work with the new shaft. 7 to 8 shift should not hesitate. 6 to 7 will have a noticable hesitation. I would pressure test trans before buying it.
