| John Deere Tractors Discussion Forum |
Topic: Re: JD 6068 engine blowing steam from blowby
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| d9gdon
01-28-2013 09:32:01
184.6.190.86
richardinnz said: (quoted from post at 22:24:30 01/27/13) Coolant pump on a 6068 is belt driven, mounted low down on the front cover, just has a ring of M6 screws holding it in after you have pulled a hose and water tube. Unless the aluminium housing it is bolted to has corroded out behind it then it would be unlikly this is your problem.
Stick the over flow hose in a bottle with water in it, bottom of hose under the water, if you get bubbles when the engine is running you have a failed head gasket, or on a later engine it could also mean a failed EGR cooler. We have been caught out with that one on a 7530 tractor, wierd build because it had a Mexican engine in a Manhiem tractor and not a Saran motor.
The engines will also suffer the same old liner troubles if the motor has not had Thermogard (I think this is called Coolgard in some countrys) in the system. There are also plenty of John Deere DTAC solutions about liner protrusion on these engines so beware to check it properley. You really need to get John Deere CTM104 for correct repair specifications. |
Well the water pump doesn't seem to be the problem or the bearings aren't out anyway. It's not looking good as nobody has ever put any Thermogard in it.
Gonna have to pull the pan and pressurize it.
BTW, it doesn't have the EGR cooler as this machine is probably a 2002 model.
I guess by the DTAC solutions you mean service updates along the way on these engines, and CTM 104 is an updated procedure for checking liner protrusion?
This post was edited by d9gdon at 09:37:23 01/28/13. |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
