Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Releasing the clutch on a burned tractor
Greenday
01-28-2013 04:26:04
if you put the transmissions in neutral it should roll any way. Are sure its not the brakes that are stuck?
Larry Kastens
01-28-2013 06:59:09
 Re: Releasing the clutch on a burned tractor in reply to Greenday, 01-28-2013 04:26:04
Thanks for the reply. The problem is that the clutch lever can not be moved to place it in neutral. All I can say is that it would have been wiser, on my part, if all the tractors were in neutral, when the forest fire came.
It is estimated that the temperature reached nearly 3,000 degrees as some cast iron wheels melted and the front axle on the MM U bent.
husker44a
01-28-2013 07:56:43
 Re: Releasing the clutch on a burned tractor in reply to Larry Kastens, 01-28-2013 06:59:09
Larry where are you located at?
Larry Kastens
01-28-2013 08:44:14
 Re: Releasing the clutch on a burned tractor in reply to husker44a, 01-28-2013 07:56:43
I am located in Ash Canyon, 12 miles south of Sierra Vista, Arizona.
My kids said I should downsize. Well, the forest fire downsized me in one afternoon. It is OK as I now get to start over.
You are probably in Nebraska according to your handle. I grew up in northwest Kansas.
husker44a
01-28-2013 09:04:01
 Re: Releasing the clutch on a burned tractor in reply to Larry Kastens, 01-28-2013 08:44:14
Yes I'm in western Nebraska. We had some nasty forest fires this past summer. I was involved in fighting it. Local Volume. Fire Dept. Seen some wild things happen. Seen a few barns that have been standing for a very long time go up in flames. A few had old cars and tractors / machinery in them. Thaught that you might be from around here.. Sorry for the loss of your barn and tractors.
