Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: JD 6068 engine blowing steam from blowby
[Show Entire Topic]  [Return to Forum]
richardinnz
01-27-2013 18:24:30
125.239.160.222
Coolant pump on a 6068 is belt driven, mounted low down on the front cover, just has a ring of M6 screws holding it in after you have pulled a hose and water tube. Unless the aluminium housing it is bolted to has corroded out behind it then it would be unlikly this is your problem.
Stick the over flow hose in a bottle with water in it, bottom of hose under the water, if you get bubbles when the engine is running you have a failed head gasket, or on a later engine it could also mean a failed EGR cooler. We have been caught out with that one on a 7530 tractor, wierd build because it had a Mexican engine in a Manhiem tractor and not a Saran motor.
The engines will also suffer the same old liner troubles if the motor has not had Thermogard (I think this is called Coolgard in some countrys) in the system. There are also plenty of John Deere DTAC solutions about liner protrusion on these engines so beware to check it properley. You really need to get John Deere CTM104 for correct repair specifications.
[Reply]   [No Email]
d9gdon
01-28-2013 09:32:01
184.6.190.86
 Re: JD 6068 engine blowing steam from blowby in reply to richardinnz, 01-27-2013 18:24:30
richardinnz said: (quoted from post at 22:24:30 01/27/13) Coolant pump on a 6068 is belt driven, mounted low down on the front cover, just has a ring of M6 screws holding it in after you have pulled a hose and water tube. Unless the aluminium housing it is bolted to has corroded out behind it then it would be unlikly this is your problem.
Well the water pump doesn't seem to be the problem or the bearings aren't out anyway. It's not looking good as nobody has ever put any Thermogard in it.
Gonna have to pull the pan and pressurize it.
BTW, it doesn't have the EGR cooler as this machine is probably a 2002 model.
I guess by the DTAC solutions you mean service updates along the way on these engines, and CTM 104 is an updated procedure for checking liner protrusion?
This post was edited by d9gdon at 09:37:23 01/28/13.
[Reply]  [No Email]
Tx Jim
01-28-2013 04:41:03
67.142.163.21
richardinnz said: (quoted from post at 21:24:30 01/27/13) Coolant pump on a 6068 is belt driven, mounted low down on the front cover, just has a ring of M6 screws holding it in after you have pulled a hose and water tube. Unless the aluminium housing it is bolted to has corroded out behind it then it would be unlikly this is your problem..
Richard
Thanks for the heads up. I was unaware that JD went back to a belt driven WP. I always thought it was "DUMB engineering" to have WP seal fail and dump antifreeze in the crankcase.such as my 4255 has done before. If I researched correctly it appears JD uses this type water pump on several different Mannheim/Saran type engines also
This post was edited by Tx Jim at 04:43:49 01/28/13.
[Reply]  [No Email]
richardinnz
01-28-2013 21:10:50
125.239.162.42
 Re: JD 6068 engine blowing steam from blowby in reply to Tx Jim, 01-28-2013 04:41:03
Yep, that waterpump went right back to the 6*10 series Manhiem tractors. DTAC is the JD Dealer Technical Assistance Centre, they are damn good, The CTM is the Component Technical Manual, the shop manual that covers the 6068 motor. BTW Manhiem don"t make engines, the 4045 and 6068 come from Saran (France) prefix CD or Mexico prefix PE. I think only the big "grunters" are from Waterloo, the 6090 and 6130, and the old 6081. Unlike the post above we have had our share of head gasket failures on both Saran and Mexican engines, they do not need to overheat, the water level just has to drop a bit, then you can bet your life that 12 to 18 months down the track you are putting a head gasket on the engine.
[Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
