Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: model L transmission
Hotflashjr
01-27-2013 09:26:33
The trans is housing also is part of the differential. Most likely you will need to remove the rear wheels and both final drives to get the driveshafts out. You would need to remove those to get the full transmission out. To replace cones and races you will need to take it all apart. It's not a bad job but you need a way to jack up the back end of the tractor and a helper to help. The cast centers are over 100 lbs. as well as the final drives. I ended up rebuilding everything in my LA while I was "in there".
sam henry
01-27-2013 18:28:53
 Re: model L transmission in reply to Hotflashjr, 01-27-2013 09:26:33
ok thanks for the info guys
Copyright © 1997-2015 Yesterday's Tractor Co.
