TractorLinks.com
Show Parts for Model:
Re: JD 6068 engine blowing steam from blowby
Tx Jim
01-27-2013 08:51:33
I agree on checking the water pump as it's driven off of camshaft/timing gears
d9gdon
01-27-2013 09:36:22
 Re: JD 6068 engine blowing steam from blowby in reply to Tx Jim, 01-27-2013 08:51:33
Thanks for all the replies! I'll check the water pump first. Glad to know it's gear driven. That could be where the coolant got in there. It hasn't been cold enough to freeze it this year and it had been tested to 20 below zero.
It didn't run but about 3 minutes altogether after it started blowing steam out. Just long enough to put the hydraulic cylinders in the transport position.
This post was edited by d9gdon at 09:39:04 01/27/13.
buickanddeere
01-27-2013 14:26:55
 Re: JD 6068 engine blowing steam from blowby in reply to d9gdon, 01-27-2013 09:36:22
The coolant can measure -20F and be no good. The corrosion inhibited is just as vital in a wet sleeve engine. , If the inhibitor is depleted, the sleeves will cavitate pin holes.
