Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Compression tester
gtx1967jewison
01-26-2013 20:27:25
Hand cranking it works fine. Make sure the throttle is wide open. Run it through about 3 cycles with a tester that holds the pressure. They need very little compression to run nice if your carb is set right & ignition is strong. To strengthen #2 try richen the idle mixture. Turn the idle mixture needle counter clockwise a full turn or more & see if it gets stronger or just smokes. I suspect weak ignition if that dont help. A sticking valve is also possible
