TractorLinks.com
Show Parts for Model:
Re: Compression tester
Cliff Nelson
01-26-2013 06:01:07
You're right that hand cranking would be too slow. Pulling it will be ok but you need to determine the correct speed for the test. Too fast will show higher compression.
gtx1967jewison
01-26-2013 20:27:25
 Re: Compression tester in reply to Cliff Nelson, 01-26-2013 06:01:07
Hand cranking it works fine. Make sure the throttle is wide open. Run it through about 3 cycles with a tester that holds the pressure. They need very little compression to run nice if your carb is set right & ignition is strong. To strengthen #2 try richen the idle mixture. Turn the idle mixture needle counter clockwise a full turn or more & see if it gets stronger or just smokes. I suspect weak ignition if that dont help. A sticking valve is also possible
