1941 model b- information-help-advice
Anonymous-0
I acquired [free] a few years back and am just getting into it. It sat ouside for years of course and is in poor shape . Got head off today and one cylinder looked good and one rusted badly. Question-Is it a sleeved engine and if not could one be bored and sleeved . Also , How does steering shaft come out ? I am trying to get hood off and I removed the end cover from steering gear but not sure what I have to do to pull the steering out so I can remove hood.
Hello-to remove the steering shaft first, pull the steering wheel off the end of the shaft. Next, remove the key that is underneath the steering wheel. Assuming that you have the crown off, remove the two bolts holding the bearing race off the front of the steering bolster. Dont damage the bearings as they can be costly. Finally, unscrew the steering shaft and worm gear off the front. The shaft comes out from the front. You might have to loosen the jam nut off the back of the bolster. As far as sleeving the engine, it dousn't have sleeves. You can take the block in to a machine shop and have it sleeved but that can become very expensive or if possible, have it bored out and just put oversized pistons and rings in it.
I hope this can help-Mike
Take a look at the photos below to remove the steering shaft with worm.
You have already removed the medallion.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2828.jpg.html" target="_blank">
IMG_2828.jpg" width="650" border="0" alt=" photo IMG_2828.jpg"
</a>
Remove the steering wheel.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2830.jpg.html" target="_blank">
IMG_2830.jpg" width="650" border="0" alt=" photo IMG_2830.jpg"
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2829.jpg.html" target="_blank">
IMG_2829.jpg" width="650" border="0" alt=" photo IMG_2829.jpg"
</a>
Remove the two cap screws securing the housing assembly to the pedestal.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2827.jpg.html" target="_blank">
IMG_2827.jpg" width="650" border="0" alt=" photo IMG_2827.jpg"
</a>
Remove the housing assembly and catch the oil and bearing.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2826.jpg.html" target="_blank">
IMG_2826.jpg" width="650" border="0" alt=" photo IMG_2826.jpg"
</a>
Twist and pull on the steering shaft until it can be removed from the pedestal.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2824.jpg.html" target="_blank">
IMG_2824.jpg" width="650" border="0" alt=" photo IMG_2824.jpg"
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/Tank%20Repair/IMG_2823.jpg.html" target="_blank">
IMG_2823.jpg" width="650" border="0" alt=" photo IMG_2823.jpg"
</a>
It may be necessary to hammer on the end of the steering shaft in order to remove it from the steering support.
If this is done, replace the steering wheel nut and drive against it with a rubber hammer.
Hope this helps.
It can be bored at least 125 thousandths. Thats 1/8". I believe you can go farther than that on that block, ask josh Blackburn or Ray @extreme Tractor parts. It can be sleeved also.
Thanks. Gonna weigh cost of sleeving back to standard bore versus oversize and having to buy new pistons. One cylinder MIGHT be okay. The other is rusted badly.
(quoted from post at 00:09:23 01/20/13) I acquired [free] a few years back and am just getting into it. It sat ouside for years of course and is in poor shape . Got head off today and one cylinder looked good and one rusted badly. Question-Is it a sleeved engine and if not could one be bored and sleeved . Also , How does steering shaft come out ? I am trying to get hood off and I removed the end cover from steering gear but not sure what I have to do to pull the steering out so I can remove hood.
Sleeves are cast in block. Normally safe to bore 250 over if needed. Can just bore to late B specs and buy pistons for late B off of this site.
