removing clutch pulley from model b 1941 model
Anonymous-0
I have removed the crankshaft nut, adjuster plate, friction discs , drive plate and the four bolt clutch lever casing and linkage. Pulley is still tight. Can I put a puller on it and start cranking using end of crank for my puller bolt or is there something else to consider ?
