Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Going to negative ground on 620
[Return to Forum]
RMOMN
01-24-2013 15:31:49
70.97.243.96
When installing a alt. and going to neg. ground. Will all the gauges still work?
[Reply]   [No Email]
Mike M
01-25-2013 05:48:04
24.140.0.120
Re: Going to negative ground on 620 in reply to RMOMN, 01-24-2013 15:31:49
If you have a working fuel gauge now on 12V + grd. It will now not work ! You will have to try and find a neg. grd. gauge.
  [Reply]  [No Email]
RMOMN
01-25-2013 06:08:23
70.97.243.96
Re: Going to negative ground on 620 in reply to Mike M, 01-25-2013 05:48:04
Thanks Mike, what gauges will have to be changed now that it is neg. ground?
  [Reply]  [No Email]
Mike M
01-25-2013 06:58:24
24.140.0.120
Re: Going to negative ground on 620 in reply to RMOMN, 01-25-2013 06:08:23
Just swap the leads on the ampmeter. The fuel gauge is the only fussy one. Did it work before ? It might not of ? If not it could also have a bad tank sender. But the fuel gauges are definatly ground specific. There are some guys around rebuilding gauges maybe they can make them both + or - grd.
  [Reply]  [No Email]
Fixerupper
01-24-2013 18:49:52
100.42.82.30
I agree with Buick all the way unless you plan on pulling an implememt that requires a lot of juice. The only time I saw a 620 changed to an alternator that really needed one was when the farmer bought a new White planter that had an electric drive of some sort, that he planned to pull with his 620. Jim
  [Reply]  [No Email]
RMOMN
01-24-2013 19:15:22
70.97.243.96
Re: Going to negative ground on 620 in reply to Fixerupper, 01-24-2013 18:49:52
I just bought the tractor to use and that was already done.
  [Reply]  [No Email]
Fixerupper
01-24-2013 20:20:25
100.42.82.30
Re: Going to negative ground on 620 in reply to RMOMN, 01-24-2013 19:15:22
OK, so now you have to work with the hand you're dealt. Like what was said, the ammeter wiring needs to be reversed, the primary wire on the coil changed so the negative side goes to the points. I've had good luck with generators on two bangers. The down side to a genny is the damage to your pocketbook when it comes time for replacement of the genny or regulator. Jim
  [Reply]  [No Email]
RMOMN
01-25-2013 06:18:47
70.97.243.96
Re: Going to negative ground on 620 in reply to Fixerupper, 01-24-2013 20:20:25
Thanks Jim, I'm sure that's why it has a alt. on it. Now I have to figure out what needs to be done so I have working gauges. Bob
  [Reply]  [No Email]
Fixerupper
01-25-2013 08:31:33
100.42.82.30
Re: Going to negative ground on 620 in reply to RMOMN, 01-25-2013 06:18:47
The only electric gauges are the fuel gauge and the ammeter. I'd be surprised if you DO have a working fuel gauge. Usually the sender gives up the ghost in those old girls. To check it out pull the top dash panel back a bit to get access to the back of the fuel gauge. It's held on by those four 5/16" cap screws that might or might or might not twist off. Find the wire that comes off the top of the fuel tank to the fuel gauge and ground the terminal it hooks to with the switch turned on. Just bump the grounding wire to the terminal in case you're touching the hot one. You should NOT have sparks at all. If you are getting power to the gauge and the gauge itself works and you are touching the right terminal it should peg full. If there's no reaction, run a jumper wire from a hot source to the power side of the gauge and try it again. When you first touch the jumper wire to the gauge just bump it to the gauge to see what happens in case there's a short somewhere that makes smoke. You'll figure it out. It's pretty straight forward. If the sender is bad they are available now in the reproduction market but I'll be darned if I remember where. Someone else might chime in. I got a repro sender and refurbished gauge for my 630 and it works fine. Jim
  [Reply]  [No Email]
RMOMN
01-25-2013 16:21:25
70.97.243.96
Re: Going to negative ground on 620 in reply to Fixerupper, 01-25-2013 08:31:33
Thanks, Jim good info
  [Reply]  [No Email]
buickanddeere
01-24-2013 18:11:25
216.46.157.212
Nothing to gain by cob jobbing an alternator onto a 620. The factory 20amp generator is a good producer.
An alternator on a two cylinder also looks butt ugly.
Coil polarity is important too.
  [Reply]  [No Email]
gtx1967jewison
01-25-2013 15:36:48
174.225.133.39
Re: Going to negative ground on 620 in reply to buickanddeere, 01-24-2013 18:11:25
20 amps wont even run a decent, practical set of healights. They draw 30. If gennys are so great why were they $hit canned for 'new-fangled' alternators? Because more power & LESS maintenance were desired. My opinion is they only belong on trailer-queens/parade toys. To each his own.
  [Reply]  [No Email]
buickanddeere
01-25-2013 19:34:14
209.240.118.116
Re: Going to negative ground on 620 in reply to gtx1967jewison, 01-25-2013 15:36:48
What are you doing out at night with a two cylinder Deere and four aircraft landing lights?
  [Reply]  [No Email]
rickdeere
01-24-2013 16:23:56
67.231.40.38
youll need to change wires around on amp gauge and coil wires
  [Reply]  [No Email]
rickdeere
01-24-2013 16:23:32
67.231.40.38
  [Reply]  [No Email]
RMOMN
01-24-2013 17:33:07
70.97.243.96
Re: Going to negative ground on 620 in reply to rickdeere, 01-24-2013 16:23:32
Will I need to do anything on the fuel gauge?
  [Reply]  [No Email]
rickdeere
01-25-2013 03:16:22
67.231.40.38
Re: Going to negative ground on 620 in reply to RMOMN, 01-24-2013 17:33:07
no I dont think so
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
