TractorLinks.com
Show Parts for Model:
Re: JD 2130 Starter Removal
Tech 7
01-24-2013 12:43:39
Was this an older 2130 with the engine oil cooler under the starter? They are nice! I have made up some different wrenches over the years. Due to my inability to post pictures I will try to decribe it in case you ever need to repeat the job: Obtain a 12" length of 3/8 rod and weld a nut on the end. Buy a cheap 9/16 wrench and cut the box end off leaving about an inch of "handle" weld the wrench to the other end of the rod so it end up looking like a L shape.I also have one with a short handle on the nut end...sort of a "speed wrench.
Charles Branch
01-24-2013 13:22:00
 Re: JD 2130 Starter Removal in reply to Tech 7, 01-24-2013 12:43:39
It's supposed to be a 1977 model. SN 238209L. I have had it about five years, and like it a lot. I use it mainly with a grapple rake on the FEL. Only problem is the Load/Depth control doesn't seem to work. On my old 1020, it works well, which is very handy for things like box blade and disc.
Tx Jim
01-27-2013 04:39:55
 Re: JD 2130 Starter Removal in reply to Charles Branch, 01-24-2013 13:22:00
L/D control probably is out of adjustment on your tractor with SN 238209L. I'd suggest going through the adjustments of L/D mechanism as outlined in the JD service manual.
Charles Branch
01-27-2013 05:15:38
 Re: JD 2130 Starter Removal in reply to Tx Jim, 01-27-2013 04:39:55
Good idea. I recall having to change the load control shaft to fix a hydraulic leak when I first got the tractor. I'm wondering if we did something wrong in that job. Sometimes when I lower the implement, it will suddenly just rise on its own.
I remember being amazed at the time when I first read how the L/D mechanism worked. I surprises me that they don't all develop leaks, what with the abuse we put on the three point hitch doing things like pushing up privet with a box blade.
Tx Jim
01-27-2013 06:36:48
 Re: JD 2130 Starter Removal in reply to Charles Branch, 01-27-2013 05:15:38
Does control handle stay where it's set when 3pt raises or does handle move also? If handle moves then the friction washers on handle are worn and need shimmed or replaced.
Charles Branch
01-27-2013 08:57:45
 Re: JD 2130 Starter Removal in reply to Tx Jim, 01-27-2013 06:36:48
The control handle stays fixed. In fact, the implement often will come back up even while I still have my hand on the handle. It's like it has a mind of its own.
Tx Jim
01-27-2013 09:35:27
 Re: JD 2130 Starter Removal in reply to Charles Branch, 01-27-2013 08:57:45
In all my years of employment at a JD dealership I never witnessed a JD utility tractor 3pt act as you described.
Charles Branch
01-27-2013 11:00:39
 Re: JD 2130 Starter Removal in reply to Tx Jim, 01-27-2013 09:35:27
My old 1020 never did that either. My neighbor noticed the same thing when he borrowed the 2130 to go over his field with a chisel plow. Whenever you want to take a vacation to East Alabama, let me know, and I'll arrange a demonstration. :) And I would even let you get the old 1020 running again too. Seriously, maybe I ought to start a separate thread on the strange lift behavior. But I'll spend some time reading the service manual first, so I'll understand better how it's supposed to work.
Charles Branch
01-24-2013 13:16:20
Thanks for the idea. I'm hoping this starter will outlive me, but I'll file your suggestion in case it dies before I do. :)
