Yesterday's Tractor Co. Trusted Parts Supplier since 1995
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 520 - clutch will not engage after bearing change???
[Return to Forum]
davidrz
01-23-2013 20:56:11
216.183.60.107
Installed a new belt pulley bearing on my 1958 520. Now, after putting everything back it will not engage. I can hardly move the clutch handle, it is very hard. Nothing happens.
I had taken the belt pully completely off several times before and have put everything back without a problem. This time I took everthing off, took out the old bearing and installed a new one. Got the new bearing through John Deere dealer and is exactly like the old one.
The new bearing is all the way in as it should be. The bearing retainer is all the way in also. However, when I put back all the facings, riveted disc, and the final adjusting disc, I barely now have enough room to start the adjusting castle nuts. And the engaging clutch handle will not move.
Have taken it apart several times and the diagrams and instructions in the JD manuals, but still have the problem.
Appreciate any advice and assistance. Help!!
Thank you. David
[Reply]   [No Email]
oakley21550
01-25-2013 20:07:30
204.111.217.123
 Re: 520 - clutch will not engage after bearing change??? in reply to davidrz, 01-23-2013 20:56:11
I hate to admit this but I had my 730 clutch apart awhile back and upon reassembling it (about six or eight attempts)could not get it to adjust. It went together but could not adjust the clutch disk adjuster. Finally realized that I was installing the disks on the clutch operating bolts instead of the clutch drive pins. This is what happens when you don"t pay attention how things came apart because you have done them several times before.
[Reply]  [No Email]
1949ABG
01-24-2013 17:15:41
208.126.169.160
I wish you luck. I did the very same thing to my A, and had your exact problem after putting it back together. I took it apart 3 times, and put it back 3 times. Same thing. I was ready to roll it down a big hill. But, I did it again, figuring it's something simple.
I'm not sure what I did different, but the 4th time everything worked as it should. I would SWEAR I did it the same every time, but apparently not. Just be extra cautious about each and every possible step. It'll fall into line sooner or later.
[Reply]  [No Email]
Dodgeit
01-24-2013 07:30:54
65.199.61.227
Off hand I would say that the clutch fork, is not in the correct location. Remove that cover and make sure that the fork is inserted into the correct groove. The other possiblity would be the pully brake not being adjusted correctly.
[Reply]  [No Email]
Tyler-MO
01-24-2013 07:30:36
50.40.143.178
David,
It sounds like one of two things could be happening. First, is the drive disk on the crankshaft going on all the way (about a 1/4 inch of difference between the end of the crank and face of the drive disk is normal)?
I've had an instance in the past where there was part of a broken clutch facing getting out of the pulley groove behind the drive disk which caused a similar problem to yours.
Secondly, it soulds like your clutch operating sleeve isn't moving into position properly. Could it be that one of the toggles slipped out of socket during the bearing change operation? How about the clutch drive pin in the operating sleeve?
These are all points that could potentially bind causing the symptoms you describe.
One thing on these clutches is that the geometry all must be together...one thing out of whack will prevent any effective adjustment.
My thoughts as simple as it may sound, would be to grab the parts catalog and go over all the clutch parts and doulbe check the proper order...we've all had similar things happen over the years.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
