TractorLinks.com
Show Parts for Model:
Re: 4020 injector pump
davida
01-23-2013 11:55:41
Main questions are there are 2 steel rods that go in the head assembly.
Where does the short one go?
What directions does the long one go, with the plunger type end toward or away from the plug?
I took it to far apart and these parts fell out before I knew they were there.
Dieseltech
01-23-2013 12:01:11
 Re: 4020 injector pump in reply to davida, 01-23-2013 11:55:41
Smaller vent wire goes in bore first. Longer goes next, one end is larger due to normal wear, grind edge down or install with peaned end next to retaining plug.
davida
01-23-2013 12:05:04
 Re: 4020 injector pump in reply to Dieseltech, 01-23-2013 12:01:11
Thank you, I thought I have tried to install them both in the same bore with not luck but I will try again.
Dieseltech
01-23-2013 12:24:22
 Re: 4020 injector pump in reply to davida, 01-23-2013 12:05:04
Glad to help. Have been repairing pumps since 1976. Will be home tomorrow nite, call if you like.
davida
01-24-2013 10:22:56
 Re: 4020 injector pump in reply to Dieseltech, 01-23-2013 12:24:22
One last question...maybe.
Is there a part number for the housing or fitting that makes up the pressure regulator sleeve assembly?
The one I have has been broken off at the top.
Dieseltech
01-24-2013 10:46:49
 Re: 4020 injector pump in reply to davida, 01-24-2013 10:22:56
Transfer cap regulating sleeve, 17058 old #, new # 27917.
davida
01-24-2013 11:17:30
 Re: 4020 injector pump in reply to Dieseltech, 01-24-2013 10:46:49
Thank you, are these JD numbers?
Dieseltech
01-24-2013 11:32:50
 Re: 4020 injector pump in reply to davida, 01-24-2013 11:17:30
These are Stanadyne #s.
