5085 m mfwd 310 loader
They have been pretty good tractors... 85M has the mechanical pump, so not too many issues there... they use a late timing event, for emissions.. and if its cold, they will white smoke during warm up... timing them correctly can be tricky...
One of the issue has been operator inficked... If you get it stuck, and need to use the diff lock.. clutch the tractor and then engage the diff lock.. If you get one wheel spinning fast, and then engage the diff lock.. it sometimes will fail.. and its not pretty... The diff lock locking collar, and not a clutch... There haven't been many failures... but I've seen a few..
