Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: 4430 quad range linkage?
Chris95
01-22-2013 17:14:06
I will try the spring. I am going to call the service manager tomorrow to ask about the detent parts being replaced. I would think they would have which makes me think it is more of an adjustment thing. There is an adjustment for the lever to the shift plate in the console?
Tim S
01-22-2013 18:09:27
 Re: 4430 quad range linkage? in reply to Chris95, 01-22-2013 17:14:06
The linkage adjustment is a turn buckle on the shift rod, to get it right you need to feel it in gear then adjust the rod to where it matches up with the shift plate, but the shift plate is for placement not to hold it in gear.
Chris95
01-23-2013 08:08:56
 Re: 4430 quad range linkage? in reply to Tim S, 01-22-2013 18:09:27
I talked to the service manager this morning. They put in all new parts including the cam and the ball detents. I am going to buy the spring to put on the shift linkage. He said to shim the spring for the ball detent, so I will try that. Thanks guys for your help.
Tx Jim
01-23-2013 03:56:23
I'll try again. Sorry for the incorrect photo but it's been many tears since I looked inside a QR trans.
Tim S
01-23-2013 04:02:51
 Re: 4430 quad range linkage? in reply to Tx Jim, 01-23-2013 03:56:23
Don't beat yourself up Jim,,I've been into 3 this month, and one waiting to come in...I know linkage "can" be the problem some times with these not staying in the ranges,,,but "most" of the time it's some thing going on with the bottom shaft area,worn snap ring grooves, worn shift collars/gears,end play issues, and such...but you need to prove the "on top" stuff first...
Tx Jim
01-23-2013 04:23:05
 Re: 4430 quad range linkage? in reply to Tim S, 01-23-2013 04:02:51
Tim
After you stated incorrect photo I thought to myself " what was I thinking" as that drum shifter goes on a syncronizer and not associated with A-B-C-D.
Tim S
01-23-2013 04:31:29
 Re: 4430 quad range linkage? in reply to Tx Jim, 01-23-2013 04:23:05
You have been doing good at posting the break down pics,,I have been up to my neck with transmissions lately, so I'm staying "fresh" on them....got a 4020 down now for a top shaft re-build..will be going back together with it today..
Tx Jim
01-23-2013 05:54:29
 Re: 4430 quad range linkage? in reply to Tim S, 01-23-2013 04:31:29
Since you mentioned I always thought it was odd back when I was a dealer service manager that repair jobs come in groups of engines then maybe trans then maybe hyd's and so on.
Tim S
01-23-2013 11:11:40
 Re: 4430 quad range linkage? in reply to Tx Jim, 01-23-2013 05:54:29
It sure seems that way here,,clutches and transmissions lately,,but that's my favorite,,I don't mind them at all....
