| John Deere Tractors Discussion Forum |
Topic: Finally Changed it
[Return to Forum]
| Author |
[Modern View]
| Tech 7
01-22-2013 07:38:12
206.47.90.66
For the last two or so years I have battled with ignition problems on my beloved 1020. Last Saturday I used the tractor for about an hour. It started and ran fine as it had the previous Saturday when I worked it for about 3 hours scraping barnyards. So after shutting it down on Saturday morning I went back to it a few hours later and it had no thought of firing. Pulled the cap off....points are trashed...SECOND set since last May.@#$%^&!!!! Went out Sunday and cleaned up what was left of the points to make it run enough to get inside. Was going to do some more work to the points but decided to bite the bullet and install the Electronic Ignition kit that I bought back in December. (just needed the right incentive I guess)The kit installed really easy considering I was working under a lean to roof at about 15 F and a cheery west "breeze" I will admit I had my doubts about this little bit of magic in a box but when I was done she fired right up and ran smooth. I guess I have become one of the converts on this board that says go with the Electronic upgrade. |
| fred from mo
01-23-2013 04:48:16
70.195.15.70
Re: Finally Changed it in reply to Tech 7, 01-22-2013 07:38:12
| I have had a kit on my 60 for the last 6 years. Best single improvement I did for the reliability of the tractor. Fires right up in damp weather. |
| Wilamayb
01-22-2013 14:53:02
71.15.146.140
| | As long as you use the proper coil and the unit doesnt get any serious voltage spikes it will work fine. I installed one in a late B around 10 years ago, and I dont think the cap has been off since that time. I installed one in a late A 4 or so years ago but have replaced it twice due to people leaving the key on overnight. It'll smoke one for sure.... Very few of these units are defective. Most failures are due to improper installation. One big mode of failure is from those who run single wire alternators. They are not usually grounded well so that they have huge voltage spikes. If they are grounded properly all is well.. My biggest reason wasnt for burned points, but rather for corroded points. My tractors sit more than they are used. In my damp southern climate the points would be varnished in no time... |
| Cliff Nelson
01-22-2013 10:12:08
69.21.97.161
| Use resistor (graphite core) plug wires. One of the first kits I installed quit after 6 months. The manufacturer warrantied it but said that metallic plug wires set up a radio frequency that damages the controller. With graphite wires that tractor is still running after 18 years and only changed plugs a couple times in that time. It is used daily. |
| Tim S
01-22-2013 10:15:45
75.49.13.105
Re: Finally Changed it in reply to Cliff Nelson, 01-22-2013 10:12:08
| I guess I've never heard that angle before Cliff,,makes sense.. |
| bigboreG
01-22-2013 09:36:02
166.181.3.161
| I had one burn out in three months. Til it did, I was happy with it. I am sold on Blue Streak points, I put those in and have had no trouble since. So I will stick with points for now. |
| Tim S
01-22-2013 09:51:36
75.49.13.105
Re: Finally Changed it in reply to bigboreG, 01-22-2013 09:36:02
| Yes that's been my experience with them, seems like any kind of voltage spike will knock them out, they are a great Idea, but I think most of them come from China so that says it all..I know a lot of guys on here seem to get along fine with them.. |
| hayfarmer
01-22-2013 09:17:31
71.80.194.62
| I have converted 2 of my tractors to electronic ignition and love it. My JD430 was also hard on points. Couldn't keep them adjusted. I went to ei and haven't touched the distributor since, I think it has been about 12 or 15 years. I also converted an IH SMTA. Both tractors were already 12 volt. Ths SMTA has also worked great. I open up the plug gap some on these tractors. I find that works for me anyway. |
| Bob Bancroft
01-22-2013 08:47:19
97.73.64.145
| Give it time. I have had mixed results. Hopefully yours will stay working. |
| Tim S
01-22-2013 09:26:47
75.49.13.105
Re: Finally Changed it in reply to Bob Bancroft, 01-22-2013 08:47:19
| I'm with you Bob,,that little box burns out with no warning and you can't go to the parts store to pick one up....your dead in the water till one comes in the mail,,Darn it..but when they work they are great.. |
| Bob Bancroft
01-22-2013 11:52:22
97.73.64.149
Re: Finally Changed it in reply to Tim S, 01-22-2013 09:26:47
| I put one in neighbors MF 65, and it worked so good that I changed his other 65. The second one quit, and fortunately I had saved the old parts! I put a unit, along with their "hot" coil in an old Dodge 318 in a truck that liked to foul plugs. I couldn't tell that it made any difference. |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
