Yesterday's Tractor Co. Low Prices, Parts Ship Fast!
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 2130 john deere hydraulics
[Show Entire Topic]  [Return to Forum]
berwin121
01-22-2013 06:52:14
68.114.100.36
had water in oil and have been using tractor all year flushes everything out with diesel and i should have filled tank up before starting but forgot so filled in back and wind up having to refill twice because it had to fill tank and lines.now arms go down after sitting for a while but once i crank it arms go up regardless where i have the lever
[Reply]   [No Email]
Tx Jim
01-22-2013 09:19:04
67.142.163.21
Re: 2130 john deere hydraulics in reply to berwin121, 01-22-2013 06:52:14
If lever doesn't control 3pt then something is wrong with linkage inside RS housing that's not related with changing hyd oil.
  [Reply]  [No Email]
Tim S
01-22-2013 07:28:22
75.49.13.105
You should never "need" to fill the tank up, if your talking about the reserve tank in front of the radiator. The charge pump (transmission pump) should flow strong enough to exceed the needs of the main pump ,fill the tank and flow back to the transmission. I'm not sure where you are on this, but if you remove the big line on the top of the front pump(the one that goes up to the tank and on to the cooler),attach a line to the pump fitting and head it into a bucket, start the engine and rev it to 1/2 throttle (of course have the trans full of oil) it should have a "strong" flow into the bucket till it starts to pump the transmission empty,if you have little to no oil coming through your problem is in the rear of the system,bad trans pump,cracked supply lines, stuck filter relief valve...These can be a hard system to understand and trouble shoot,,but this is where to start.I'm working on a 2030 now that had weak and chattering hydraulics,I ran the test i just described and had "strong" flow, so I pulled the main pump and found a pump inlet valve backed out and pounded the threads out, this let the oil sputter back like a bad engine valve popping through the carburetor.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
