Yesterday's Tractor Co. Tractor Parts for All Brands
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: 4010 LP-Hard Starting
[Return to Forum]
Toby Harter
01-22-2013 05:56:52
132.3.57.68
My friend has a 4010 LP Standard that is having an issure. Sometimes it will pop right off and other times it won't start at all. I have checked all electrical connections, replaced the cap, rotor, points, and condensor. It's full of propane as I have loosened connections and made sure it has propane all the way to the converter. I'm just wondering if there is something simple I need to do or should check out. Thanks for the help fellas!
[Reply]   [No Email]
TIMAR
01-22-2013 16:33:56
208.92.171.160
 Re: 4010 LP-Hard Starting in reply to Toby Harter, 01-22-2013 05:56:52
PERTRONIX INGNITION AND A 2 12V BATTERIES. My 70 LP 4020 fired up like my fuel injected truck after this. Also, after you turn on key and the VAPOR ONLY, give it 5-10 seconds for the vapor to reach the carb
[Reply]  [No Email]
rickdeere
01-22-2013 10:23:00
67.231.40.38
If it starts right up when cold or for the first time that day, and harder to start after that the same day its your hydralic presure, try turnning steering wheel or moving hydralic lever when its hard to start should start right up.
[Reply]  [No Email]
Tx Jim
01-22-2013 12:30:55
67.142.163.23
 Re: 4010 LP-Hard Starting in reply to rickdeere, 01-22-2013 10:23:00
If hyd's is causing engine to crank slowly you could install and use a destroking screw(parts key #6).
This post was edited by Tx Jim at 12:35:51 01/22/13.
[Reply]  [No Email]
rickdeere
01-22-2013 16:32:51
67.231.40.38
 Re: 4010 LP-Hard Starting in reply to Tx Jim, 01-22-2013 12:30:55
I agree
[Reply]  [No Email]
Roger In Iowa
01-22-2013 08:06:12
166.182.3.210
Friend"s 4020 has a hole in the center of the regulator where you can use a small nail or screwdriver and it acts like a primer bulb. You can hear it hiss. Seemed to help starting. Key had to be on or no hiss.
[Reply]  [No Email]
Wilamayb
01-22-2013 07:03:50
164.144.248.26
The key to getting an LP to start is a hot spark. Close the throttle almost all of the way when cranking.
If your converter is in poor condition it can cause poor starting also.
An LP fuel system in good condition is very similar to fuel injection. It starts and runs good regardless of how hot or cold it is.
[Reply]  [No Email]
John A.
01-22-2013 06:42:47
64.128.16.238
Toby,
Are you starting on Vapor? not liquid! An old Trick used to start 4010 & 4020 LPs is to rotate the steering wheel about 1/3 turn back and forth in rapid succession. it seems to drop the pressure that is generated in the front pump and helps starting. Why, It just seems to start better. At times My LPs will start in 3 to 5 revolutions other times 6 to 10 I know there is nothing wrong. I think it has to do with ambient outside air temps. there are times LP just will start better than others. Hope this helps.
Later,
John A.
[Reply]  [No Email]
Tx Jim
01-22-2013 06:08:07
67.142.163.22
You might check the oil level in the air cleaner bowl. Have you considered changing points/cond to electronic ignition??
[Reply]  [No Email]
Texasmark1
01-22-2013 06:42:06
198.45.243.137
 Re: 4010 LP-Hard Starting in reply to Tx Jim, 01-22-2013 06:08:07
I had a 4020 LP and spent a lot of time and money trying to get
reliable operation out of it and it just didn't happen. Every day,
every hour, different time of day, different engine temp, all were
a variance in getting it to light off.
However, in support of your suggestion, I did get CD ign. for
mine and it helped a lot.
Oh, and that was the same tractor that I bought that had these
little holes down the side of the block with oil oozing
out......HA!....another cost of an education........during the
overhaul I realized that it was a premature failure caused by the
previous mechanic (who-whatever that was) put the wrong color
sleeve seal against the fluid to be sealed; had them backwards.
Selling that sucker and buying a diesel was one of the best
things I ever did.
Mark
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
