Yesterday's Tractor Co. We Have the Tractor Parts You Need
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: smoke normal on JD2640
[Return to Forum]
svenandersen
01-21-2013 19:10:16
50.123.210.234
I have a JD 2640 and when it idles, I get some (white) smoke coming out under the engine. Is this normal? How much?
[Reply]   [No Email]
buickanddeere
01-22-2013 06:33:26
184.151.61.51
 Re: smoke normal on JD2640 in reply to svenandersen, 01-21-2013 19:10:16
Cold idle, warm idle? Looking at smoke against a blue or grey sky? Or against an outline of trees?
What about smoke at fast idle?
Hours on engine and condition?
Ever service the injectors?
Any smoke at full load?
Oil consumption?
[Reply]  [No Email]
svenandersen
01-22-2013 06:52:10
168.236.84.93
 Re: smoke normal on JD2640 in reply to buickanddeere, 01-22-2013 06:33:26
Thanks for your information and advice all you guys.
It's grey smoke against the grass grass. I only notice it when its in park and there's no air movement. I don't really know about slow/fast idle. It's got 5000 hours. I've only had it 6 months and I don't know about the injectors. Again, because I've put so few hours on it, I don't know about oil consumption.
[Reply]  [No Email]
buickanddeere
01-22-2013 09:18:38
184.151.61.51
 Re: smoke normal on JD2640 in reply to svenandersen, 01-22-2013 06:52:10
Slow idle is no load and 700 or so rpm. Fast idle is approx 2400rpm and no load.
Consult the operators manual for the actual numbers.
Obtain a coolant test kit from the dealer that tests the corrosion inhibitor which few operators seem to even know about. If the coolant is old or originonal. The wet sleeves maybe cavitated through and why the previous owner sold the tractor.
Run an oil analysis kit on the crankcase oil . Don't need to add to problems with antifreeze tearing the bearings out.
[Reply]  [No Email]
Tx Jim
01-22-2013 03:55:42
67.142.163.22
Moisture will also cause more visible blow-by(vapor) coming out breather tube. Remove rad cap while engine is cold,crank engine and look for tiny bubbles in coolant.
[Reply]  [No Email]
svenandersen
01-22-2013 06:53:52
168.236.84.93
 Re: smoke normal on JD2640 in reply to Tx Jim, 01-22-2013 03:55:42
Just to follow up, if there are bubbles, that means.........?
[Reply]  [No Email]
Wilamayb
01-22-2013 07:09:09
164.144.248.26
 Re: smoke normal on JD2640 in reply to svenandersen, 01-22-2013 06:53:52
Tiny bubbles in coolant would mean that combustion is reaching the cooling system from either piston liners, cylinder head gasket or cylinder head.
[Reply]  [No Email]
leon
01-22-2013 03:15:44
173.30.193.163
That's called blow-by - combustion gasses blowing by the piston rings into the crankcase, then vented out of the engine block by a vent tube that extends downward toward the bottom of the engine. Some blow-by is normal. It's much more visible in the winter than summer.
[Reply]  [No Email]
svenandersen
01-22-2013 06:56:04
168.236.84.93
 Re: smoke normal on JD2640 in reply to leon, 01-22-2013 03:15:44
Thanks for your reply. That's what I was hoping to hear. There's no visible liquid (oil, water) showing around vent.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
