Ignition and wiring questions
John 37A
I am working on a 52 A and am down to spark and wiring. The tractor has been converted to 12 volt, but how can I tell if it is positive ground or negative? I hooked it up with + ground and it spun the engine over, but I had no spark.
I would like to switch to electronic ignition, and if I do, assuming it is + ground, what all is effected? Ammeter wires need switched and generator needs polarity switched? Anything else?
Thanks,
John
Does it have a alternator? Most are negative ground. Check the wire from the coil to the distributor. It should be the same as the ground on the tractor.
