TractorLinks.com
Show Parts for Model:
Re: no fuel to injectors on a 2555 JD
Tx Jim
01-21-2013 03:54:49
There's a metering valve in the inj pump that could be stuck. What is the tractors history?? Has it been sitting idle for a while or running and just stopped?? It's possible that the head and rotor are worn out. Do you know if pump is turning with the engine as the pump drive shaft could be broken??
Poultryman
01-23-2013 18:55:23
 Re: no fuel to injectors on a 2555 JD in reply to Tx Jim, 01-21-2013 03:54:49
The pump is turning with the engine. I'm getting fuel through the filter and to the pump. I even changed the fuel filter to make sure it was getting enough pressure. But i can take off a injector line and i'm get no fuel through the pump.
Tx Jim
01-24-2013 09:33:06
 Re: no fuel to injectors on a 2555 JD in reply to Poultryman, 01-23-2013 18:55:23
Sounds as if the metering valve in IP is stuck. Remove line from valve(parts key #2) and se if fuel comes out while engine is spinning over.
This post was edited by Tx Jim at 09:39:37 01/24/13.
