TractorLinks.com
Show Parts for Model:
Re: John Deere 2 Cylinder Cam Bearing Question
FactoryFarmer
01-20-2013 17:50:36
A lot, kinda....
Build a drive system without a shaft or anything that does not block the swing of the crank, cam is chain driven from a sproket behind the flywheel, cam is above the valves with bcket tappets.
Eliminates cam and pushrod flex and rocker arm breakage. I was running 2000 before and plan to run a lot faster with this setup.
gtx1967jewison
01-20-2013 18:24:10
 Re: John Deere 2 Cylinder Cam Bearing Question in reply to FactoryFarmer, 01-20-2013 17:50:36
That is awesome id love to look at it :-) someone needs to make billet cranks & a 4-valve head so you can run 3-4000 rpm & stomp the red crowd in open classes!
