Loader tractor recommendation
REDEYE
I am looking at a 6300 MFWD, powerquad,reverser with a 640 loader. Will be used to clear some land, maintain some roads and mowing brush. Some of the trees/stumps that i wanted to dig out are 18". Do you think this is a good match and will the powerquad hold up to loader work? I was also considering a 210LE as a backup option but they don"t have a pto.
JD's farm loaders aren't built to the same spec's as industrial frt end loaders. I would be very hesitant to attempt to dig out an 18" stump with a farm loader.
i would use a back hoe to dig a stump that size, or cut it a bit hi and use a dozer. u may get it with your loader but it'll be hard on it.
As previously stated. That tractor vs. even a 6" stump is being optimistic. Unless you are using a backhoe and have cut all the roots.
Hire a dozer.
You'd really want an industrial tractor for moving dirt and stumps, but for general farm work, that's a bulletproof transmission and a good tractor. It'll dig up most stuff, but stumps are the realm of a trackloader and backhoe.
