TractorLinks.com
Show Parts for Model:
JD 4520 Air Conditioner Mounting??
Josh4520
01-20-2013 12:26:40
Thanks to all who replied on the earlier fuel line question! I am also looking at adding a air conditioner to this tractor. Most tractors I have seen from the new generation have the a/c pump on the left hand side down by the side rail. My tractor has part of the engine casting in the way. Where are you supposed to mount the pump on this thing? any ideas? Homemade remedies?
donmyeil
01-21-2013 06:17:13
 Re: JD 4520 Air Conditioner Mounting?? in reply to Josh4520, 01-20-2013 12:26:40
I mounted one on the right side frame. Had to use an idler and 4320 crank pulley . Worked for many years for a comercial applicator.
larryanderson
01-20-2013 13:58:49
There used to be a company by the name of Eagle Air that installed many A/C in older tractors before air became almost standard in the Sound Guard bodies.A/C has come a long ways but I dont remember seeing any 69 4520s with it.The 71/72s have a special place to mount it.Anything can be done just takes time and money.
Tx Jim
01-20-2013 12:35:32
Factory AC compressor mounting brackets look very similar to late model 4020's & 30 series RC tractors. Mounting on LH frt side of engine. I just looked at the engine blocks and there was a SN break. If your engine block has no place to mount compressor then you'll have to mount it under the engine behind the frt axle same as some older 4020's.
AR50297 CYLINDER BLOCK 1 - 303518 (NLA) (MARKED R43310 OR R45980) (SUB FOR AR43496) (ALSO ORDER AR43852, AR48289, R32617, R46158, AR52160)
AR52061 CYLINDER BLOCK 1 303519 - (MARKED R47020 OR R47110) (SUB RE70108, SHORT BLOCK) (NLA)
This post was edited by Tx Jim at 12:39:57 01/20/13.
Josh4520
01-20-2013 12:55:58
 Re: JD 4520 Air Conditioner Mounting?? in reply to Tx Jim, 01-20-2013 12:35:32
Thats what I thought at first. But when I looked at my tractor, part of the engine block was in the way. I included a picture that shows what I mean. NO this isnt my exact tractor, but it was a picture I found on the internet that showed the casting that is in the way (I am not by my tractor right now)
Tx Jim
01-20-2013 13:02:49
 Re: JD 4520 Air Conditioner Mounting?? in reply to Josh4520, 01-20-2013 12:55:58
Can you take a close-up photo of the same area?
This post was edited by Tx Jim at 13:12:05 01/20/13 2 times.
Josh4520
01-20-2013 13:15:25
 Re: JD 4520 Air Conditioner Mounting?? in reply to Tx Jim, 01-20-2013 13:02:49
I zoomed in a bit on the picture I found. I am in another state right now on business. Was planning on going to a junk yard next Saturday out here and was wondering if I should add a a/c mount to the list, wondered what they looked like etc. I hope this picture helps.
Tx Jim
01-20-2013 13:29:51
 Re: JD 4520 Air Conditioner Mounting?? in reply to Josh4520, 01-20-2013 13:15:25
The side mount for AC comp.will not work on your block. You need a bracket for underneath. I don't think there's enough room to mount compressor over the engine similar to the JD utility tractors.
Josh4520
01-20-2013 13:34:14
 Re: JD 4520 Air Conditioner Mounting?? in reply to Tx Jim, 01-20-2013 13:29:51
Do you have any pictures of the under mount? Know anyone who has done something like this before?
Tx Jim
01-20-2013 13:58:35
 Re: JD 4520 Air Conditioner Mounting?? in reply to Josh4520, 01-20-2013 13:34:14
I had forgotten until I looked in the parts catalog #859 that JD once offered a side mount bracket for the Delco compressor that bolted to the 2 holes in the LH frame rail that the holes were designed for a frt rockshaft. Just open up the PC #856 go to parts index type in this number(AR48199) and it will take you to the page. There was also a bracket for over the engine part # AR44967. I beginning to think the underneath bracket I was thinking of was aftermarket mount for a Year-A-Round or Hiniker cab
Normally I would download the parts photo but my new computer with Win 7 pro is giving me photo "Nightmares".
Josh4520
01-20-2013 14:07:52
 Re: JD 4520 Air Conditioner Mounting?? in reply to Tx Jim, 01-20-2013 13:58:35
Thanks!! This gives me a good place to start. thanks again for putting up with my questions!
Tx Jim
01-21-2013 06:05:26
 Re: JD 4520 Air Conditioner Mounting?? in reply to Josh4520, 01-20-2013 14:07:52
Here's some parts photo's.
