TractorLinks.com
Show Parts for Model:
Re: John Deere 2 Cylinder Cam Bearing Question
FactoryFarmer
01-20-2013 10:14:00
I'm not saying its like changing a tire but I just don't think its all that bad, although because of what it does take to change it is on of the reasons I'm going to an OHC on my G.
Again, not saying its hardjst time consuming.
bigboreG
01-20-2013 13:01:05
 Re: John Deere 2 Cylinder Cam Bearing Question in reply to FactoryFarmer, 01-20-2013 10:14:00
I am interested now. An OHC on a G? Whats that entail?
FactoryFarmer
01-20-2013 17:50:36
 Re: John Deere 2 Cylinder Cam Bearing Question in reply to bigboreG, 01-20-2013 13:01:05
A lot, kinda....
Build a drive system without a shaft or anything that does not block the swing of the crank, cam is chain driven from a sproket behind the flywheel, cam is above the valves with bcket tappets.
Eliminates cam and pushrod flex and rocker arm breakage. I was running 2000 before and plan to run a lot faster with this setup.
gtx1967jewison
01-20-2013 18:24:10
 Re: John Deere 2 Cylinder Cam Bearing Question in reply to FactoryFarmer, 01-20-2013 17:50:36
That is awesome id love to look at it :-) someone needs to make billet cranks & a 4-valve head so you can run 3-4000 rpm & stomp the red crowd in open classes!
