TractorLinks.com
Show Parts for Model:
Re: 620 knock
bigboreG
01-20-2013 08:58:00
What about the clutch driver and flywheel? Are the splines good on both? You mentioned new bearings, does that include main bearings also?
DGK
01-20-2013 10:27:48
 Re: 620 knock in reply to bigboreG, 01-20-2013 08:58:00
Machine shop fitted rist pins bored block. flywheel and clutch driver tight. Cam gear looks good but seems like coming from that area. Pulled clutch side off and checked cam bearing was good. checked other side was good. Plastic gauge rods were good. Just seems like in cam area. I reset valves a couple times. Thanks Doug
2-banger
01-20-2013 17:14:11
 Re: 620 knock in reply to DGK, 01-20-2013 10:27:48
id guess rods need to be rebushed for wrist pin but you said they fitted them? i had a late a and driver was off mark on crank it sounded bad and shook..
rla
01-21-2013 04:59:31
 Re: 620 knock in reply to 2-banger, 01-20-2013 17:14:11
Don't forget aluminum pistons can make alittle noise when they are not under load?? Play with your timing alittle..
