TractorLinks.com
Show Parts for Model:
Re: JD 2155 stuck in forward after brake issue
Tx Jim
01-19-2013 14:29:15
I agree with Cliff. I think the ball you referred to is the detent ball for F-N-R in the hyd reverser control valve.
MK Smith
01-20-2013 08:09:27
 Re: JD 2155 stuck in forward after brake issue in reply to Tx Jim, 01-19-2013 14:29:15
Removed the cap and the ball/spring were jammed tight inside the cap. The fork shaped ball seat must've rotated fwd before I re-installed the cap causing the spring to fold up and then the ball wedged up inside. Got the ball out and the cap will clean up but the spring is chowed. Hoping the assy inside the housing isn't damaged.
Any idea about a part number on the spring or specifically where I'd find an expanded view and what the part is called? Does this site have a preferred parts supplier? Thanks for the help. Mike
