| John Deere Tractors Discussion Forum |
Topic: Re: JD 2155 stuck in forward after brake issue
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| MK Smith
01-19-2013 13:30:40
96.252.224.209
Looked closely and there is nothing binding the linkage from the handle down to where it enters the gear case. With the engine running I tried every combination of fwd/rev/gear ranges/clutch engaged/disengaged. Shut it down and tried again. It shifts in/out of hi/low and runs through the gears fine but it's still locked in fwd. Would it have anything to do with the cap I removed or can I rule that out? Thanks, Mike |
| MK Smith
01-20-2013 05:36:52
96.252.224.209
Re: JD 2155 stuck in forward after brake issue in reply to MK Smith, 01-19-2013 13:30:40
| | If it can "over travel" that might explain why it didn't seem to seat as far down on the re-install. I couldn't see down in the hole with the foot rest in the way but could move the ball around with my finger and didn't feel an indentation for it to sit down in. I'll try and jam my cell phone camera in there this morning to figure it out. How would I return the ball seat back to it's proper spot to re-install the ball/spring without possibly causing an issue? Thanks again, Mike Thanks, Mike |
| Tx Jim
01-20-2013 06:05:10
67.142.163.22
Re: JD 2155 stuck in forward after brake issue in reply to MK Smith, 01-20-2013 05:36:52
| Mike
IIRC there are only 4 bolts that hold footrest on the tractor. I think I would remove footrest for a better view. |
| MK Smith
01-20-2013 08:16:15
96.252.224.209
Re: JD 2155 stuck in forward after brake issue in reply to Tx Jim, 01-20-2013 06:05:10
| | It'd be far easier and I probably should but I'd have to cut them off with a torch and then find replacements. I'd hoped that I wouldn't need to get that far into it but may have to if a new detent spring isn't the answer (see post and pics in response below) Thanks for your input. Mike |
| Tx Jim
01-20-2013 09:14:20
67.142.163.20
Re: JD 2155 stuck in forward after brake issue in reply to MK Smith, 01-20-2013 08:16:15
| You can order the part from JD dealer R33277 SPRING ADD 2.38
You can view parts schematic at JDparts.com I would download a parts photo of it for you if I could get my "new to me Windows 7 pro" to cooperate
This post was edited by Tx Jim at 04:45:22 01/21/13 2 times. |
| Cliff Nelson
01-19-2013 13:39:32
69.21.97.161
| The spring and ball is the detent for the reverser valve so yes that is likely your problem. The ball should go in first, then the spring. I don't recall if the arm can over travel with the detent out. |
| MK Smith
01-19-2013 18:56:48
96.252.224.209
Re: JD 2155 stuck in forward after brake issue in reply to Cliff Nelson, 01-19-2013 13:39:32
| | Thanks I'll ck it tomorrow. It didn't seem to lay right in the center when I put back on and I was very aware that it spun off with no pressure but wouldn't go back on by hand, so something moved or didn't go back together just right. Thanks again for your help. Mike |
| Tx Jim
01-19-2013 14:29:15
67.142.163.24
| I agree with Cliff. I think the ball you referred to is the detent ball for F-N-R in the hyd reverser control valve. |
| MK Smith
01-20-2013 08:09:27
96.252.224.209
Re: JD 2155 stuck in forward after brake issue in reply to Tx Jim, 01-19-2013 14:29:15
|   Removed the cap and the ball/spring were jammed tight inside the cap. The fork shaped ball seat must've rotated fwd before I re-installed the cap causing the spring to fold up and then the ball wedged up inside. Got the ball out and the cap will clean up but the spring is chowed. Hoping the assy inside the housing isn't damaged. Any idea about a part number on the spring or specifically where I'd find an expanded view and what the part is called? Does this site have a preferred parts supplier? Thanks for the help. Mike |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
