Replaced my left brake line, bled the lines, topped off the hyd fluid and now the tractor is stuck in fwd. It has a power shifter on the left side of the dash that wont budge from fwd.
It may be nothing but I can only imagine that when I was looking to refill the brake housing, I removed the only bolt/cap that looked like it might be a filler cap from on top of the brake pedal assembly. It was just inboard of the two brake cylinders and had a 1" head and a spring & ball underneath it. I merely replaced it but couldn't see if the ball/spring returned into their specific seat. It seemed to have a bit of tension on it until it was seated.
Other than that the line went in fine and the assy went ok too. I'm at a loss. Any clues would be helpful. Thanks, Mike
