Round spoke wheel
Papa Fox
I Have a 9x36 cast in hub rear wheel with casting # ABX 36580. Believe it is an F&H wheel. Cast in hub is broken. Has anyone had any luck with cutting out the cast in center, boring appropriate holes , and using a bolt in hub? Its a nice wheel & would like to save it if possible. Any thoughts or advice?
Yes, It can be done, I have a set of factory flats on a unstyled B that where originally 12 spline and the ears where broke. They have been drilled out with 10 spline bolt in hubs installed. You can't tell when they are on the tractor.
