4020 ROPS/ Canopy foam pad
df
Anyone have a outlet for the part. # R47197 Pad for the underside of a New. Gen canopy besides Deere?
The foam pad in the cab roof of my JD 310A backhoe started turning to dust 5 years ago. Got tired of having the stuff fall on my head and down my neck. Took my pressure washer and removed it all then I put a piece of shag carpet reminant in the roof to quiet things back down. Works better than the original piece. It is a PITA to get the Kirby up there to keep it clean though...
When I restored my 4000 I went to wal mart and got a mattress pad. I cut it to fit and glued the egg shell side up leaving the smooth side showing. Much cheaper than deere
Here is the info. FehrCab InteriorsCo. @ Fairbury ILL. 815-692-3355.www.fehrcab.com. You will want to measure the canopy yourself. The JD part# is not big enough. I used a 1/2 inch for the first layer to go between the ribs and then a 1" with the finished one side as one piece over the whole thing.
They have the glue you need. Call me @ 217-259-3508 if you need to discuss further
