Yesterday's Tractor Co.
Shop Now View Cart
Show Parts for Model:
4020 ROPS/ Canopy foam pad
01-19-2013 09:46:08
Anyone have a outlet for the part. # R47197 Pad for the underside of a New. Gen canopy besides Deere?
Dannie Gingerich1
01-21-2013 06:08:18
 Re: 4020 ROPS/ Canopy foam pad in reply to df, 01-19-2013 09:46:08
Here is the info. FehrCab InteriorsCo. @ Fairbury ILL. You will want to measure the canopy yourself. The JD part# is not big enough. I used a 1/2 inch for the first layer to go between the ribs and then a 1" with the finished one side as one piece over the whole thing.
They have the glue you need. Call me @ 217-259-3508 if you need to discuss further
01-19-2013 13:24:27
When I restored my 4000 I went to wal mart and got a mattress pad. I cut it to fit and glued the egg shell side up leaving the smooth side showing. Much cheaper than deere
Cliff Nelson
01-19-2013 11:45:30
K&M ( offers bulk foam that is the same as original. Reasonably priced also.
01-19-2013 11:05:45
The foam pad in the cab roof of my JD 310A backhoe started turning to dust 5 years ago. Got tired of having the stuff fall on my head and down my neck. Took my pressure washer and removed it all then I put a piece of shag carpet reminant in the roof to quiet things back down. Works better than the original piece. It is a PITA to get the Kirby up there to keep it clean though...
Dannie Gingerich1
01-19-2013 10:01:47
I replaced mine last summer from a good source in ILL. I can get you the address , phone number on Monday. Turned out real nice
01-19-2013 11:38:18
 Re: 4020 ROPS/ Canopy foam pad in reply to Dannie Gingerich1, 01-19-2013 10:01:47
Ok thanks a lot.
