Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Show Parts for Model:
Re: Unstyled B Rear Steel Wheel Removal.
greenday
01-18-2013 17:45:02
Youre best bet would be to build a puller. If you try to spread the cones on the wheel hub to much they will bust off dont ask me how I know this. A peice of 1" thick steel plate cut to a 10 - 12 inch diameter circle then drill the holes in them to match the ones in the wheel and use 3/4" diameter all thread and nuts. Screw the all thread into the wheel then slide the plate steel onto the all thread till it hits the end of the axle screw a nut onto each all thread then start tightening them evenly and the wheel should start moving. Make sure to clean the axle up very well first to make it slide easier. Hope this helps. Dave
