Use PB Blaster or some other penetrate on the splined axles/wheel hubs long before you start removing the wheels.
Clean the splines with a rotary brush to remove any rust.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1490.jpg.html" target="_blank">
</a>
Use a flat file to remove any burrs or flat spots on the splines.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1493.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1505.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1503.jpg.html" target="_blank">
</a>
Once you get the splined axles cleaned, use a jack to raise the wheel to be removed.
Be sure to "block" the other rear wheel, front wheels, and drawbar.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1484.jpg.html" target="_blank">
</a>
Put penetrate on the wheel hub, tap the hub with a small sledge hammer, rotate the wheel and repeat the process.
We used a similar method that [b:654c4848f0]clampdaddy[/b:654c4848f0] described below to remove the collars then the wheels on "Uncle Earl" our 39B.
Here's a photo of an old mechanical jack used to move/remove wheels.
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Easy/IMG_1472.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/IMG_1651.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/IMG_1650.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/IMG_1649.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/IMG_1648.jpg.html" target="_blank">
</a>
<a href="http://s200.beta.photobucket.com/user/jameslloydhowell/media/John%20Deere%20Equipment/Uncle%20Earl/IMG_1647.jpg.html" target="_blank">
</a>
Hope this helps.
