TractorLinks.com
Show Parts for Model:
Re: Z-weights on a 4455
rockyridgefarm
01-18-2013 09:42:07
Yup, they should bolt right up. You'll need to take them all off to get the longer bolts that hold on the first weight. Best part is I doubt you'll need all 5 as the 4455 should be considerably heavier right out the gate.
I'd come over and help you, but I have a thing going on this afternoon... :-)
Tx Jim
01-18-2013 10:38:46
 Re: Z-weights on a 4455 in reply to rockyridgefarm, 01-18-2013 09:42:07
The Z weights will not fit because of the different style rear wheels. My 4255 doesn't have rack & pinion rear wheels and the Z weights I had wouldn't fit and I'm fairly confident 4455 rear wheels are the same.
This post was edited by Tx Jim at 10:44:04 01/18/13.
tomstractorsandtoys1
01-18-2013 16:04:24
 Re: Z-weights on a 4455 in reply to Tx Jim, 01-18-2013 10:38:46
Tex were the Z weights changed when the 4440's came out to a bigger center? I was told once that the 4440 and bigger tractors needed the latter weights with the bigger centers. Our one 3020 has a set of the bigger center weights on it.
Tx Jim
01-18-2013 16:34:32
 Re: Z-weights on a 4455 in reply to tomstractorsandtoys1, 01-18-2013 16:04:24
It's been many years since I installed weights on a tractor but I think I installed Z weights on 4440's at the JD dealership where I worked. I know for a fact that the 4240 that I traded in on the 4255 had Z weights on it. Those are the weights I tried to install on my 4255.
I looked in 4440 parts catalog but it showed different weights than the Z weights.
rockyridgefarm
01-18-2013 12:15:25
I'll accede to TX Jim's comment and retract mine. He's more likely to be right than I am.
