JD 4010 throttle linkage
BECAREFUL; Soak up the small bolt on the clamp so it is free. Dont twist it off. Then tighten up the clamp to hold. If it does not hold, the lining is wore out.
As stated tighten bolt(parts key #13) Worse scenario replace lining(parts key #12 R26958)
