Yesterday's Tractor Co. Same-Day Parts Shipping Available
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Show Parts for Model:
Topic: Re: 2630 flywheel timing bolt hole, with broken pin?
[Show Entire Topic]  [Return to Forum]
chickenfriend
01-15-2013 12:39:36
76.4.85.97
Thanks.
I finally decided to drill out the hole about 3-4 more mm, enough that a bolt will go into it enough to be perpendicular and index the flywheel to the frame sufficiently.
I used a drill size just under 3/8"
My neighbor has a 2030. When I get a chance, I 'll probe the depth using the housing cover hole, or if he ever has to replace his starter, I'll measure it directly.
At this point, the hole is good enough to get a TDC reading, so that is taken care of.
I am not sure how much any of the pin left in the flywheel is going to affect the flywheel balance, probably not anything to worry about, I never go over 2100 rpm.
This post was edited by chickenfriend at 06:01:42 01/16/13 7 times.
[Reply]   [No Email]
chickenfriend
01-16-2013 06:23:16
76.4.85.97
Re: 2630 flywheel timing bolt hole, with broken pin? in reply to chickenfriend, 01-15-2013 12:39:36
Yesterday, I did get a reply back from John Deere (which I should have been more patient for).
Here is the information they sent me. Perhaps there are one or two people out there that this may help:
"This tractor shows 3 flywheels, but the timing pin hole dimensions are the same on all of them as below:
.368 Drill .120 [3,05] Deep
.550 [13,97] x 120 degree csk"
The .368 drill is between 23/64" and 3/8". Originally, I thought is was a 3/8" drill, but that is a little too big. Why I assumed that was because a 3/8" bolt is the largest size that will fit through the pin hole in the flywheel housing.
I don't have the original bolt-pin that secured the timing plate to check the diameter (because it was sheared-off).
I assume the .120 is the depth, which is not very deep, only 3mm, about what my hole was originally, I think. So maybe it was ok, afterall.
The chamfer on the hole is by a .55" drill with a 120" countersink.
Typical lesson learned here is not to assume anything (I seem to re-learn this regularly).
This post was edited by chickenfriend at 07:40:51 01/16/13 5 times.
  [Reply]  [No Email]
Tim S
01-16-2013 06:41:38
75.49.13.105
Re: 2630 flywheel timing bolt hole, with broken pin? in reply to chickenfriend, 01-16-2013 06:23:16
I was kinda thinking it was about the right depth so that if it was turned with the pin in it would push it out and away from the flywheel. A guy that worked with me at the dealership hit the starter on a 4230 with the pin in the hole, it bend and stuck, he had to split the tractor to free it...
  [Reply]  [No Email]
chickenfriend
01-16-2013 07:24:10
76.4.85.97
Re: 2630 flywheel timing bolt hole, with broken pin? in reply to Tim S, 01-16-2013 06:41:38
Yes. I was thinking the same thing, knowing what I do now.
Perhaps they had a good reason not to make that hole no deeper than necessary; and with a little bit of play with the pin in the flywheel housing, it was more likely that the pin would be pushed out if accidentally left in.
It just didn't seem to me that 1mm was much of an insertion depth into the straight hole, and I had a local John Deere mechanic tell me the depth was about 3/8", he thought.
I don't have the original pin, but if the end is rounded ( I think it was) or tapered, it is possible it also fits the chamfer region, too, and in that case, the pin could have a 3/8" diameter, indicating I was thinking the wrong way about it.
If I need a substitute pin, I use a section of brass or cheap steel, and not something like grade 8.
This post was edited by chickenfriend at 07:43:51 01/16/13 9 times.
  [Reply]  [No Email]
Tim S
01-16-2013 07:35:08
75.49.13.105
Re: 2630 flywheel timing bolt hole, with broken pin? in reply to chickenfriend, 01-16-2013 07:24:10
The original pin was soft, the big thing is not to forget and crank the engine with it in...it's a locator, not a lock. I've god a 2030 out side waiting to come in..I'll look at it closer when I split it..
  [Reply]  [No Email]
chickenfriend
01-16-2013 08:05:02
76.4.85.97
Re: 2630 flywheel timing bolt hole, with broken pin? in reply to Tim S, 01-16-2013 07:35:08
Tim S said: (quoted from post at 08:35:08 01/16/13) The original pin was soft, the big thing is not to forget and crank the engine with it in...it's a locator, not a lock. I've god a 2030 out side waiting to come in..I'll look at it closer when I split it..
Thanks.
There is just a little more to this story; I may be purging an anxiety I have had for many years.
Not only had I assumed the pin was broken off in the flywheel, I also assumed I had broken off a section of the flywheel.
In fact, every couple of years, I would call the dealer to find out how much a new flywheel was. Last check was $1000, up from 500$ a few years before.
What I saw though the timing plate access hole was a cavity or hole in the flywheel right next to the ring gear. The corners of the cavity are jagged and beveled, and to my untrained eye, looked like something broken-off.
Now that I have a better view, through the starter hole, I see these cavities are part of the flywheel design. I think there are 4 cavities on the edge of the flywheel, each 90 degrees apart.
The edges of the cavities are a little jagged and not a neat machined look. I would bet that the sharp edges were purposely beveled in some fashion, to reduce the chance of stress risers at those points.
This post was edited by chickenfriend at 08:13:40 01/16/13 8 times.
  [Reply]  [No Email]
[Show Entire Topic]     [Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
