TractorLinks.com
Show Parts for Model:
Re: Replacing Lift Pump
Cliff Nelson
01-15-2013 10:07:32
Are you talking fuel lift pump or transmission pump?
David G
01-15-2013 10:17:20
 Re: Replacing Lift Pump in reply to Cliff Nelson, 01-15-2013 10:07:32
Transmission pump
Cliff Nelson
01-15-2013 10:30:48
 Re: Replacing Lift Pump in reply to David G, 01-15-2013 10:17:20
Sorry, still need more info. Tractor model and transmission are necessary before we can help.
David G
01-15-2013 10:34:02
 Re: Replacing Lift Pump in reply to Cliff Nelson, 01-15-2013 10:30:48
4020D syncro
Tim S
01-15-2013 10:45:25
 Re: Replacing Lift Pump in reply to David G, 01-15-2013 10:34:02
You will need to remove the rockshaft to get to kit,,then a simple un-bolt and reinstall, you may need to rotate the differential a bit to gain access..Oh and drain the oil out,,make sure you get the suction and pressure pipe into the holes at the base..I"ll have pics after bit I got one coming in for a top shaft re-build,,it"s still setting on the trailer...
