Replacing Lift Pump
David G
What kind of a job is it to replace that pump, we are rebuilding engine and main hydraulic pump? The check valve is bad already.
Yes........But it would be extremely helpful to know just what you are working on. Check Valve???That pump?? Main pump? Fuel pump? injection pump? windsheild washer pump? Gosh I am starting to post like B&D!!
You will need to remove the rockshaft to get to kit,,then a simple un-bolt and reinstall, you may need to rotate the differential a bit to gain access..Oh and drain the oil out,,make sure you get the suction and pressure pipe into the holes at the base..I"ll have pics after bit I got one coming in for a top shaft re-build,,it"s still setting on the trailer...
